S197 05 4.6 3v NA Track Build in Progress, Dark Horse Build Thread Profile - S197 Mustangs
5
20
United States
Nice to see another 3 valve on here. Be sure to check out Project Superbeater for some tips, and things to avoid along the way.
Welcome to the sight.
Nice! Got mine at about 162k and almost completely bone stock. It's at about 193k now, and still running strong.
I definitely felt your pain about the AC crapping out, as I live in Florida as well (although I'm moving to the Northeast some time next year). My compressor kinda seized and went kaboom, and sent shrapnel through all of my AC internals. Had to get all new AC components.
Other than the old 3 valve spark plug problem (mine are definitely not the stock 2 piece anymore) and 3 inch brake ducts being much easier to install over 4 inch, what else would you recommend avoiding?
6,429
8,336
There is a cooling mod on there someplace that will be important.
I'd avoid the spark plugs AND breaking the through bolt in the diff. I'd definately avoid that..lol
6,429
8,336
This..
5
20
United States
This..
Hmmm, my sister has an 08 mustang GT... lol
So, if I understand correctly, this mod makes the thermostat open when it actually should, and the early S197's created too much pressure in the heater cores at high rpm and would pop them?
8,336
Yes, basically, it improves the t stats reaction, and up grades the under plenum tubing, some of those cars already have a built in restrictor, some do not, they all need one. The fan mod is also a must
FWIW, all that was created by " JEFF F" an engineer on the old FR500C program at Ford.
