380mm Brembo Rotors / PCV Delete Canister Setup
Selling my original Peterson PVC delete canister setup for track use. Some of you may remember I made a few of these for the members here. It is one of the first I did so it is not cosmically flawless. The bottom of the can has been dented from someone (not me) over tightening it,however that is not visible when installed. The canister itself works perfectly as intended.
More info here
It includes all the parts needed for a simple snap on install. It has the bracket designed by another member here so you do not have to drill the firewall. The PVC valve replacement tube (OEM Ford part) and two vacuum caps included.
$215 shipped lower 48
Pair of 380MM 15"Brembo Racing rotors 09.8528.74 and 09.8528.74 LH and RH These were used for a Grand Am qualifying session and about 5 laps. They have not been cleaned, there was little time for build up in the slots.
The 09.8528.74 LH has about 31.60 left and the 09.8528.74 RH has about 31.10 left of 32mm.
OD 380mm, Thickness 32mm, 10 X 258mm, 72 Vanes
$350 +15 shipping lower 48
Hats are Sold but I have one last set of floating hardware,, 20 bolts 20 bushing but only 18 washers, lost two somewhere. $30
SOLD---->Pair of hats for the 14" 355mm rotors. Comes with the floating hardware (over $110 new just for these)
BRE-16B77001 (2) MUSTANG Front Bell w/09A02613/23
Brembo Floating Hardware, 8mm (Torque 62 in/lbs)
BRE-05579320 (20) WASHER. M5
BRE-A10834105 (20) BOLT. SHCS. M5X0.8X20MM
BRE-X203026 (20) BUSHING. DISC MOUNTING. 8MM FLANGE
$300 shipped lower 48
