Aim configuration file
For those that are using a Aim dash, which configuration file are you using and what channel are you able to get from the ECU?
I have an MXP Strada and so far the only interesting channel I was able to monitor is the RPM and Water temp.
The others channel that I would like to monitor are not working. Like CHT and IAT are stuck at -40, Steering wheel angle is at 638deg and both TPS and Pedal position are at 0 and not moving
Everything is up to date and I've tried both the Boss302R file and the 2011Mustang file in the RS3 software with the same results.
I'm also able to monitor those channel in Forscan so that means that they're on the bus.
Car is a 2012 Boss 302.
Any suggestions before I contact Aim?
Thank you
Florian
Apex Wheels
Race Proven, Street Approved
Supporting Vendor
668
1,056
Bay Area, CA
I'm having a similar issue with the MXL Pista on my 2011 GT. Same monitors read -40 and such. I've been on the phone with AIM and a couple of their dealers and everyone says the same thing..."huh, it should work".
