Fabman
Dances with Racecars
Yesterday was an exciting one.
After months of waiting I finally received a big batch of Ohio based parts on a pallet and can finally commence assembly.
There is a long long lead time an any major cortex parts right now. They might say otherwise, but expect at least half a year to be safe so you don't get yourself caught in scheduling issues.
That said, their parts are gorgeous, what a delight to have those parts at hand now and I cant wait to test them out on track.
I went with this one:
Spal Electric Fans IX-30102049
wow...just wow.Wow did this week took a turn.
Story time. Before I moved to the Gen3 I had forum member Andrew Weidemann work on my Gen1. The request was to add cams and springs and refresh the motor for good measures, timing chains and pumps.
After that it never ran properly again, kept throwing p0014 and other codes and could not be tuned. In short, he moved to a different state, effectively leaving the problem on my table to sort and pay and eventually claimed not to be responsible anymore.
Well heck, so I took the covers off this weekend to get an idea what is wrong with it. Keep in mind that this was an original Gen1 long block from 2010 that has never been opened or tampered with, aside from adding a larger oil pan and oil cooler. I never had any issues with it, never left me stranded and ran like a little old champ and to its last day was one of the fastest s197s in SoCal.
Discovery
The p0014 code indicated a possible issue with the timing. But the chains and timing checked out. Rear chains were spot on and the front chain was off by 4, but evenly. Not perfect but no real issue here. Okay good, but why the codes?
I noticed a whole bunch of sticker gunk on the chain guides which led me to check the oil pan and the pick up tube.
Oil Pick-up tube
This is what I found. It looks like a mix of baffle plastic, stickers and paint. Who knows what got sucked down further.
The gunk in the pick-up tube was certainly limiting the oil flow, which explains the p0014 cam timing code as the phasers will receive inconstant oil pressure and not actuate correctly.
For reference and a good watch in general: "Coyote Cam Phasers, how they work"
I see big plastic chunks, small plastic shreds, blue paint and a whole lot of other stuff which appears to be stickers and white paint.
Oil Baffle Debris
The oil baffle was cut by the builder to make swapping the oil pump easier. I know for a fact that debris dropped into the pan that he had to fish out. I was told this would not be an issue, the plastic will be crushed, burned up and I could flush it just in case. I did a lot of flushing but it looks like some bigger pieces did not come out of the baffles pan and ended up blocking the pick-up tube.
View attachment 84520View attachment 84521
Stickers
The real head scratcher are the stickers though. Why anyone would leave them on is beyond me. Low effort, high risk. The residue where the stickers used to be is still clearly visible.
View attachment 84532View attachment 84533View attachment 84538
Using a stethoscope camera I found even more stuff behind the chain guides.
For reference, this is how these guides usually come. One can only guess how much sticker material went through the block, oil, phasers and filters.
View attachment 84539View attachment 84541
Paint Chunks
Paint that has been used to mark cam and chains gotten loose, made it to the oil pan as well as the pick-up tube filter.
View attachment 84535View attachment 84536
More plastic debris in the oil pan.
Other Annoyances
Found the balancer like this. It was hammered on with a piece of wood. I was told that is easier and a good way. Did this cause the chips in the balancer? I don't know but it looks plausible.
Scratched head. No idea, could have been Ford.
Radiator fan was not hooked up, leading the car to overheat right away when bleeding the coolant.
What now?
1. Is this state acceptable for a $7500 cam and spring upgrade and oil, water pump and timing refresh?
2. What possible other effects could the gunked up pick-up tube have caused?
