Clutch cable broke
39
52
Clarksville, TN
The saga continues!!!
Just picked up my car from the tuner (3 hours away) and a mile down the road this happens.
Luckily the 200+ Miles was mostly highway and I was able to rev match.
I have found a couple videos/how-to’s on clutch cable installs. Any one here have any hints/tips/tricks from personal experience? One of my friends mentioned something in regards to the throw-out bearing and how it could be damaged if the clutch cable isn’t adjusted corrected after install? Any one have insight on this?
Thanks!
#revmatch
6,429
8,333
Was the clutch just replaced?
It is pretty straight forward, try to get a factory Ford cable. You can also get a quadrant and an adjuster at this time if you so choose. You'll be on your back under the dash for awhile so bring some pillows for padding and a decent light.
Not too difficult if you are a contortionist.
39
52
Clarksville, TN
The clutch was replaced before I bought it. The previous owner had receipts for it.
Hahaha, thanks for the tips. I honestly think I'll just remove the seat to make it even easier.
