Dedicated Track conversion
justy keeping busy until I get the car back from the painter. Ill be at Daytona Fri-Sun. Should have the car back next week.
Ordered the Forgeline wheels. Same size & offset as the GT4. Ordered APR CF 71" wing. Suspension parts have arrived and ready for install. Went with AP Racing brake setup to fit the 18" wheels.
Fabman
Dances with Racecars
6,580
8,243
Sweet!
Fabman
6,580
8,243
I notice there isn't much droop in the suspension.....hmmmmm.
Fabman
6,580
8,243
If you limit your droop I imagine you can limit body to a certain degree as well.
Reducing pressure on the inside tires doesn’t sound like such a good idea...
Installed the steering assembly, rivnuts for displaced ground wires, trimmed the lower IP to clear door bars. Almost done with the IP installation. Most of the wiring is reconnected. Did not run into any wiring issues but I won’t really know until I power everything up. All the connectors are unique so that makes it easy to put back together.975cc40a4b2219a69281ff5d1ef1ffe3.jpg
