Different Oil Separator Installations
Thinking about getting an oil separator on the passenger side... Was wondering if anyone had any opinions about JLT versus Moroso...The Moroso looks more durable and I like the fact that is has all metal fittings. Looks like you might run into less problems with it breaking... Any thoughts? (I know the Moroso is a little more expensive, but I'd rather pay a little more if it's going to last longer. I heard though that I might need to replace those"heater hoses" as they're not really designed to withstand oil)
38
22
Los Angeles
Thought I would respond and provide some clarification and gauge the interest in having brackets made
1) Material - If I make them they would be made out of steel, not aluminum, and not SS. More than likely it would be 12ga, i will see how the look and feel, might even go down to 14ga. If wanted I can powder coat them in either black, red, or leave them raw
2) Design - The design that I was planning on making was the original design that I believe someone posted a drawing for. I have the dimensions and specs from Ricky. Which looks similar to this, which I believe is a no drill bracket/attachment
Re: Different Oil Separator Installations
I created my own design, which I was not planning on making. Mine did require drilling 2 holes. It is a little more heavy duty, and again is made from sheet metal
I have had zero issues with this, and really no chance of it breaking. If there is interest in this one I can make it as well.
So what I am needing to know for those interested in the brackets, and reading what I posted about the material and design(s). Is the interest still there, and what design, or type of bracket do you want?
Where can I get one of these bracket?
38
22
Los Angeles
I meant this bracket.
