- Thread starter
- #21
unrealford
Mustang owner since 84
- 521
- 0
yesseca954 said:Are you using the stock 3:73 gears?
unrealford said:yesseca954 said:Are you using the stock 3:73 gears?
Justin said:I have the BBR lowers on the car now and the Steeda upper with bracket sitting in the garage. Jeep what hole did you use on the steeda bracket and what did you set the length to?
Justin said:yeah I have the DSS shaft. Steeda's directions just say pick a hole try it and adjust as needed so not much help there. I am going to set the angle to -2 using the middle bottom whole and go from there I guess.
oh I'm talking about the upper control arm bracketJustin said:[quote aeepinocala link=topic=3059.msg50582#msg50582 date=1348606513]Justin said:yeah I have the DSS shaft. Steeda's directions just say pick a hole try it and adjust as needed so not much help there. I am going to set the angle to -2 using the middle bottom whole and go from there I guess.
Hey my misstake I have all steeda except I did not like their relocation bracket so I went with this UMI. With this setup you dont have to adjust pinion angle for trying the spots out they are on a radius of the control arm one of the reasons I went this route.
http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=12_184&products_id=319
