2Fass240us said:18x10 +42 clear too
I know +42 is the offset for the rear wheels, but this also works on the front? Is a spacer needed and if so, how big. Do you have any pics of the wheel install over the GT500 6-piston brakes?
Hey, what is the part number for the Brembo 15" pro kit?ArizonaBOSS said:Sexy time.
I can't say for certain on the Ford 15" brakes, but the 18x10.5" Enkeis do clear the Brembo 15" Pro Kit. Not by much.
If someone could get a decent radial measurement of the OEM Brembo caliper installed, we might be able to do a comparison vs. the Brembo Pro Kit drawings. I won't put money on it, though.
BigTaco said:Hey, what is the part number for the Brembo 15" pro kit?
Thanks,
BT
voodoo child21 said:Patrick
Sorry thought you were talking about the 13-14 setup. I don't believe the '15+ 6 piston calipers fit on S197 spindles and I also heard the pad shape is different and is not yet supported by the race pad manufacturers. Any major race pad manufacturer will custom line backing plates if you furnish them though.
I saw a post that 15's fit on 14 and below. Someone tried successfully. But only calipers. You need to use 14 GT500 rotors or the like. The offset on 15+ is different.Boy was I wrong here!!!
I know, I was the one who did it. LOLI saw a post that 15's fit on 14 and below. Someone tried successfully. But only calipers. You need to use 14 GT500 rotors or the like. The offset on 15+ is different.
Sexy time.
I can do it sometime this week. @opmustang-tim might have a template as well. If not I’ll try to get one built
THX. I hit Tim up with an email last night. Planning to buy through him if I can verify fitment.
For street and track with 18x9.5" wheels, 255/45. Street only, 265/40.what are people running width wise, non-staggered with the 9.5" wheel?
