FS: combo lap/sub belt mounts for S550 and GT350
SOLD! I have a set available in satin black. The driver's side is new. The passenger side has been installed and belts attached, but has never been actually used. It has a few minor marks from where it was bolted down and clips attached. Also, coating is a little more glossy. Really hard to tell the difference though. I will sell the set for $255 shipped. SOLD!
13
South Florida
To use a 5 or 6 Point harnes with the recaro seats in a gt350 your first post has pic of a bar mounted in the back seat area. Am I understanding correctly? If so how does it mount and is there any mods necessary? Is the back seat bar a one piece mount for both driver and passenger seats?
My mount fits under the rear seat mounting tabs and is used to mount the lap belt and the sub belt of a harness. You will also need a bolt in roll bar or harness bar to mount the shoulder belts too.
JDee
Ancient Racer
1,817
2,018
5 miles from Mosport
Thanks. Trying to figure out best way to get the shoulder harness set up for a daily driver
I would suggest taking a look at Schroth Quick Fit Pro, for a dual purpose car it works very well. You can leave it in place all the time and it is unobtrusive. Shoulder harnesses use the back seat belt anchors. Does not have sub straps but with their ASM technology it mitigates that problem. No roll bar or harness bar required.
