Ghost 2017 Build
Both good choices. Do they come in 305’s?
Also consider NT01’s in 305.
Don’t forget to use our TR link st the top of the page. :cool:
209
178
Colorado Springs
No 305's. There is The Drivers Edge HPDE Driving School I'm going to in June. By requirements all new drivers have to run on 200TW tires. But believe me if Michelin doesn't come out with a tire size to fit 18x11, I'll be getting the NT01's when I back for good in November.
Apex Wheels
Race Proven, Street Approved
Supporting Vendor
668
1,056
Bay Area, CA
Things are getting pretty serious in here :cool: Great to see the wheels arrived safely Tommy and thank you again for your business.
JRZ RS ONE's are a great way to go. We put together custom suspension packages using JRZ RS dampers as the centerpiece, and have had fantastic results.
Looking forward to more photo's as this build progresses.
- Ryan
209
178
Colorado Springs
30 days from now I get to drive the car and it's been unbearable :(. And the next day the wrenching begins, however I've been wondering about the suspension settings and where to start camber, caster and toe. I know it's trial by error, but I guess I should contact JRZ and/or For Performance to get some insight.
209
178
Colorado Springs
I'd contact the shop where you purchased the JRZ's from to get a baseline starting point. For camber -2 will be good for street and track or more for just track. If you're going to adjust back n forth between street and track go at least -2.5 for track.
I looked up Ford Performance Track Handling specs with their recommendation of;
Front Camber -1.55
Total Toe- 0
Rear Camber -1.98
Total Toe 0.23
Will adjust the Front Camber to -2 as a starting point and adjust from there. As I work my way from the tires up...this is definitely something I need to understand and pay attention too.
Apex Wheels
Supporting Vendor
668
1,056
Bay Area, CA
Front Camber -1.55
Total Toe- 0
Rear Camber -1.98
Total Toe 0.23
Those specifications from Ford Performance wouldn't be optimal for your application Tommy. If you want to leverage your new wide wheel/tire package and JRZ's, you will need substantially more negative camber up front. If you plan to run 315's, you are going to need that camber for proper front fender clearance as well. How often do you plan to track the car and how often do you use the car on the street? Setting the car up for double duty work will always introduce compromises of course.
We sell custom JRZ suspension packages as well, and whenever we get a set into a clients hands, we follow up with a pretty comprehensive chassis setup email. Acquiring and installing a capable suspension package is only half the battle, setting it up with a good benchmark and then understanding how to make continuous adjustments is essential to get ROI. Since you got the RS ONE's, things wont be very complex. If you sourced these from Maxcyspeed, I would give Stuart a shout as I understand he is quite knowledgable with this chassis.
You will want to start with relatively neutral toe settings (with a little toe in at the rear), and then make tweaks down the road depending on your driving style, local track layout and how the car is reacting etc. The idea is to shake the car down in somewhat of a neutral state, allowing yourself to relearn the limits the chassis with the new suspension and wheels and tires. A lot has changed already, so you do not want to get over ambitious with some of the alignment settings form the get go.
Shaking the car down:
  • Use a pyrometer. High temps or wearing on the insides of the tire will indicate less camber is needed. You are not using the center-meatiest part of the tire under cornering. Conversely, High temps or wearing on the outside shoulders of the tire will indicate more camber is needed.
  • Keep a journal or log. Each time you pull into the paddock, record tire data (temps and pressures) and make adjustments. Record cold pressures and hot pressures so you understand the rise and fall (nitrogen will mitigate this).
  • Purchase a suspension quick reference guide. Out on track you will need to monitor the cars behavior, and be able to recall those experiences once the session is over. Use a quick reference guide to tune the suspension and tire pressures accordingly.
The shop you purchased the suspension from may have alternate baseline recommendations for your RS1's based on their testing, but JRZ supplies baseline damper settings with every kit as well.
Start here and complete a few sessions prior to making any changes to get familiar with how the new suspension and alignment has effected the cars ability to negotiate corners, ride over berms, commit to braking zones and throttle on corner exit. To dial the suspension in further to suit your tires, track layout and ultimately your driving style, start increasing rebound by 2 to 4 clicks each session until you start to loose grip (adjust front and rear independently, one at a time). Then back off by single clicks to fine tune. Once front and rear rebound settings are dialed in, repeat the procedure with compression.
Whether you are adjusting ride height, alignment, damper settings, or tire pressures, be sure to do things one at a time while journaling them. The idea is to make an incremental change to the car, get out on track, and get an understanding of how the car has changed - for better or worse.
It is a process, but it's a fun process : )
- Ryan
209
178
Colorado Springs
- Ryan
Thank you so much Ryan for the information. I will research a log and/or create one to annotate the things you've mention and the process going forward.
209
178
Colorado Springs
As I'm making my list for things to take to MSR Cresson, what are somethings you would recommend taking? I'm thinking engine oil, brake fluid, air pressure gauge, extra set of brake pads...all my tools are locked up in military storage, but I think I should take some with me. Chair, refreshments, some type of cover since we will be outside mostly?
369
146
Waco, TX
They do have a air conditioned building and nice place to sit up there. Ideally if you could I’d take a pop up with you to sit under under with tools etc. I’d call them and ask if you can have it. It will save your life. The heat is building here and there’s nothing out the other than race control/classroom and covered paddock. There is a cover Pitt stall but not if you have to rent that.
They are really folks I’d just call out there and see what they say.
