GT350 external fuel guage
Does/has anyone added an seperate fuel level gauge on a stock setup? Aim is super cool and doesnt have a pid for the fuel guage on their dash for the gt350 so i have no clue what amount of fuel i have in the car. Would like to tap into the sending unit and run a autometer in the dash vent or something
Assuming the OEM sender uses resistance, you'd have to know the ohm range of the OEM sender and try to find a gauge that uses the same range.
You can add fuel to the Aim dash by adding an adapter to convert the resistance to a 0-5V output. You still need to know the OEM resistance range to have the adapter calibrated. It's been a while but I'm pretty sure I used Iron Canyon Motorsports for it but that was for an SN95 so can't help with your settings.
steveespo
Lord knows I'm a Voodoo Child
4,116
2,257
Cookeville TN
The in tank senders are not very stable or accurate during track conditions. I don't think you will see accurate informations. What you might try is picking up the fuel flow numbers in lbs/hr and converting that into a formula to read number of gallons. I think Chris @captdistraction might be able to help get the correct CAN info.
Im pretty sure the oem is 0-360ohms
225
373
CA
Any luck with this? I am working on hooking up my fuel sensors to the aim and looking for a proper resistor or converter right now.
I found "Low fuel = 15 ohms +/- 2. Full equals 160 ohms +/-2" and "180 +/- 4 ohms when empty, 10 ohms +/- 2 ohms when full"
My tank is pretty much empty and reads 150 ohm on the multi meter, which check out.
