C7 B8 said:Which size and pattern did you order?
I went with the GA1R open lug 11x19 24 front / 11x19 62 rear. Running Michelin psc2 305/30ZR19 all 4 corners.
8250RPM said:To date I have the parts in hand and ready to install:
ARH Long tubes
ARH Off road X pipes
JLT CAI Paint to match
JLT Coil covers paint to match (installed)
BMR Rear lower control arm bearings
BMR Vertical links
BMR Toe links
BMR Adjustable sway bar links
BMR Cradle bushings (delrin)
BMR Diff bushings (aluminum)
FORD Performance Knuckle toe bearing
Maximum Motorsports caster camber plates
FORD OEM rear seat delete (installed)
GT350R front springs
GT350R rear springs (yes they are different)
GT350R calipers (I like red and they are cheaper then powder coating the stock ones)
BOBS dual oil catch cans
Lund Flex fuel tuner
ON ORDER AND WAITING:
Forgeline GA1R open lug 11x19
Michelin Sport cup 2 305/30ZR19
Custom interior pieces, Alcantra shift boot, E brake handle and boot, center arm rest, center stack sides
WAITING IN LINE:
MGW shifter
Carbon fiber 1 piece driveshaft
GT350R splitter
SOON:
Watson 4 point
Harnesses
fuhrius said:I'm curious what you're trying to accomplish? ie. is there a method to the madness?
8250RPM said:I went with the GA1R open lug 11x19 24 front / 11x19 62 rear. Running Michelin psc2 305/30ZR19 all 4 corners.
ArizonaBOSS said:Awesome wheels. Please post pictures once you get them installed on the car.
