S550 GT350R Race Car Build Build Thread Profile - S550 Mustangs
@spartan @8250RPM
Interested in this approach. What are you leaving together and relocating?
The harness has been moved from the steering column to the center panel (plenty of length to do that). I will mount the switch on the carbon fiber panel. This approach eliminates the use of the wiper controls which I don’t need.
Worse case scenario
You can use a separate switch for the wipers and turn signals.
A on off switch would work for the wipers and a momentary switch would work for the turn signals.
I do not believe the FP350S and GT4 use the oem multifunction switch.
The problem is all the controls go through the clock spring and module.
1,955
2,160
Agreed, but the majority of track organizations will require either turn signals or wipers or in most cases both. Driving a track in the rain is the best way to learn the car.
Wiring for wipers/washers/Hi Beam (required for driving on the track at night, which is awesome!) and turn signals is a lot of effort, especially as all the controls will be in un-familiar locations for most of us amateur drivers -- sure professional race car drivers, racing the GT4, are used to that. Most of us (unfortunately!) are not...
I understand what you mean.
My car isn’t as bare as yours and Spartan’s, I haven’t seen the clock spring / SCCM apart yet in person.
If the clock spring or clock spring tape could be retained why couldn’t it be contained inside the column housing and the steering wheel buttons be located on either side of the steering column and also retain the multifunction switch?
1,955
2,160
Right now I think that's the best solution. The only concern is the clock spring ribbon is folded at 45* for entry/exit to the housing -- a potential failure point from fatigue from vibration.
The decals have shipped so they should be there by the weekend.
1,955
2,160
Decals arrived - Thanks!!
Finished up the Race steering wheel install. Wired red buttons for horn.
Ended up opening up the clock spring and using the rear half with a slot cut in the bottom as the male SCCM connector:
Then ran the ribbon under the column behind the air bag cover using the front half of the clock spring as the gauge pigtail connector, zip tied in place. This approach allows re-use of the clock spring retaining screws in the column to prevent the SCCM connector shaking loose and re-uses the clock spring housing at each connector to protect the folded portions of the ribbon.
Monted the multi way switch on the airbag panel (Airbag removed).
1,955
2,160
Hopefully the car will be ready for shakedown late May. Should get to VIR with it later this season. Doing the Superfest/Chin VIR event next month with the R.
Meanwhile, got clear film applied to the GT4 splitter and canards:
