S550 GT350R Race Car Build Build Thread Profile - S550 Mustangs
1,936
2,036
Had some really good racing at Gingerman last weekend. Very closely matched with an M3 that out qualified me twice, but managed to pass. Improved overall positions over the weekend as the track got slower. Unfortunately Reverse gear failed, so pulled the Transmission today and dropped off at Liberty's:
Couldn’t you have done this with a base mustang instead? You would just need a crate illuminator engine. I think it would have saved money and a GT350R.
1,184
2,186
The backstory is long and starts on page 1 of 46 - it’s definitely worth the read so I won’t spoil it other than saying it’s not what you think.
1,936
2,036
Here's a bit of the history before page 1 of this thread:
ArizonaBOSS
Because racecar.
8,730
2,734
Arizona, USA
Nice work at Gingerman. Ran against Vanucci at COTA a couple years ago, dude is quick. Almost 6 seconds margin of victory for your final race--good stuff!
1,936
2,036
Picked up the Transmission from Liberty's. They did a great job with fast turnaround.
Turns out the output shaft nut had worked loose, allowing reverse gear to shift (pun intended) rearwards on the shaft. Symptom was reverse lockout but this failure also caused thrust damage on the 3rd and 4th driven gear, Blocker rings, Cluster bearings along with the Reverse gear and Synchro.
Parts bill was over $1,600, but they did a refresh including Bronze Fork pads.
Apparently this is not the first 3160 failure due to the output shaft nut backing off. So beware if you're running a 3160. I've now paint marked the nut and will check 2x per season (even although it requires Driveshaft removal).
759
1,133
TX
Thanks for sharing, Nick. Did you happen to ask them about any trans upgrades? Dog-legs or gear upgrades?
1,936
2,036
They installed Bronze Fork Pads, Shot Peened the Sync teeth and performed surface enhancement to reduce friction on the Hubs & Sliders.
225
312
Virginia
Nick, is there a torque value on the output shaft nut or is it a torqued to a certain tolerance that effects something within the transmission?
Looking good. Which one is faster?
