S550 GT350R Race Car Build Build Thread Profile - S550 Mustangs
Any thoughts of replacing the sway bars? I use Eibach front and rear bars. They made a huge difference along with cortex adjustable end links and delrin bushings.
1,940
2,048
@8250RPM I'm going to use the Ford Performance Rear bar to give adjustability.
Any replacement bars should have flanges next to the bushings (check the OE bars) to prevent lateral sway bar motion under loading. Lateral motion can take out the ride height sensors.
387
DFW, TX
It's a 25mm bar. Not much bigger then the stock R rear bar of 23.87mm.
.984 vs .940. Plus the Eibachs are adjustable.
The oem of course are not.
You are right, for some reason I thought the R was 13/16". Smallest rear sway bar I can get away with is what I like to run.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Those mirrors look like Terminator mirrors.
ArizonaBOSS
Because racecar.
8,733
2,735
Arizona, USA
A little surprised to see this route myself, but I think it will offer good insight into the true performance potential of the MR system in a race application. From what I've seen in most rulebooks, these are either banned outright (pro level) or not yet considered (club level) for enforcement. You may be a pioneer here.
Are you planning to run the CorteX MR controller unit?
1,940
2,048
So here's my logic -- I salvaged more than half the MR stuff, and figured I'd give it a try, especially as there's no real data yet on MR v's coilovers. Other considerations were that the car needs a shake down, without too many changes to compare with the GT350R and the FR350S specs and parts will likely not be available for some time.
Everything is coming together great - off topic; where'd you get the Boss Track Attack stickers you've got on the lift?
Steve
