I'm trying to keep this short...I've recently started tracking my car and I'm getting some hood shake/lift/flutter at higher speeds. I've added the trackspec side vents which have helped some, but still see some shaking around 130mph. On the plus side, they also helped a lot with heat.
I also changed the front grill a long time ago to an open mesh style grill (upper and lower).
So my question is...would adding the trackspec center vent in addition be enough to eliminate this hood shake? Is there anything else I should do? Should I add the available wickers?
Would changing the front grill back to a more stock style or block off the current grill in some way help?
Thanks!
Thanks!
