Ok I’ve searched this as much as I can, here and on any other forum I can find. Can’t find a consensus.
I’m looking to install my new seat and harness as safely as possible. I’m willing to do some fab work and break out my welder if needed.
Priorities:
-Separate harness mounting from seat mounts to distribute load.
-Design and execute in accordance with most of the stricter standards which state not to place any mounts into sheet metal.
So other than building a cage with nodes that terminate where you will incorporate harness mounts how does one execute sub mounts and especially the trans tunnel lap belt mount without building them off of or through sheet metal? Seems that I have no choice, so then how to execute as strong as possible.
My current thought is to make the biggest 1/8” plates I can fit in a given area, hopefully 6”x6” or bigger per mounting area, round corners and radius edges and weld in. Then weld on or through-bolt double shear harness mounts. I think for subs this should be sufficient since they see much lower loads than lap belts. But how about for lap belts?
Option two would be these or something like these:
https://www.izzyscustomcages.com/product-page/double-shear-racing-harness-mount
My other idea for the trans tunnel lap belt would be to build a plinth/box as you would for a cage tube end and weld on a double shear tab. Not sure there’s enough space to do this though even if it were the best idea.
So anyone whose spent time lying in bed trying to figure this stuff out please chime in!
P.s. the below link is one of the better compendiums of info on harness mounting I’ve found so far.
Priorities:
Motorsport harnesss installs - forum info compilation / FAQ
. Similar to the Roll cage installation guide, this draws together various information on installing race harnesses, some of which is already spread...
www.clubgti.com
