JRI's weeping.
602
539
My rear JRI's have been weeping shock oil since new, This normal for this set? I have ran Inverted shock before and can't recall them ever leaking. Not dripping, just "wet". The bottom of the shock, shaft and bump stop are damp. I wipe them off, drive it and then have to wipe them down again. They only have 1K miles on them. Whats your take for those who are or have used them.
I had a little bit of moisture on my rears but nothing that concerned me. I kept an eye on them though just in case. If you're not happy Winter is a good time to send them in for service.
Grant 302
basic and well known psychic
I just have a little at the adjuster (DA) units. Both look about the same and not any worse than any motorcycle shocks I've owned, so I don't worry about it. I'm not seeing much on the shaft or bumpstop.
