open trailer for GT350 - what size?
2,205
1,069
Bay Area
That is so cool! And probably well worth the money. The biggest problem with my trailer is the ramp angle is too extreme so I had to buy longer ramps, an even with that, the car I loaded tonight was too close to the front spoiler, and my 18 GT has a lower front spoiler than that car has.
Are you using raceramps? Of you are you might need to add some wood for the extra lift you need.
Another member here @honeybadger might have some pics and/or solution for you.
Something else to consider.... WIDTH. I had to modify my open trailer to get my GT350 to fit on it. The spare tire mount is on the side of the deck just in front of the right side wheels. I had to modify (trim/grind) the bracket as my front track width (outside of tires) is only one inch narrower than the deck.
If I was shopping for one today, I'd look to see if there were any with more clearance between the fender wells and a couple more inches on the deck, if possible.
Featherlite 17’-6”. You’ll need race ramps to load and unload the car
20ft ATC with dovetail. Leaves enough room for toolbox and fuel cans.
And there's only about 2-3 inches clearance from the wheel to the fenders, but the fenders are removable.
28
19
Kwik load rollback trailer. Width works fine for the GT350, fenders come off to get in and out.
ArizonaBOSS
Because racecar.
8,733
2,735
Arizona, USA
That Futura trailer is legit. Buddy that works out here at U-Haul has one for testing/demo. VERY nice. Not cheap but painless load/unload and they offer a variety of rock-guard/storage options.
Picked up my Futura end of last season. Really happy with it so far.
Solar power for the recovery winch and for the winch that lowers the trailer. Rock blocker, tire rack and wheel tie downs it came to $13k. Buy once, cry once is my motto...
One of the best things about it is how light it is, I can raise it off the tow hitch and move it by myself.
A lot can be said for doing things right the first time. Nice trailer! How do you get access to tie down the front wheels with the rock guard in place? Do you have a photo of where the solar panels are mounted?
