P0100 2014 GT500
12
10
North Carolina
Anyone run into a P0100 issue before? Long story short she shut down on a track day (alternator died and cut power) have since replaced MAF and alternator and still have a no start condition. Any advice?
12
10
North Carolina
Is the battery healthy? Fully charged with charger on?
Yes sir, I may have it tested just in case but it's only 2 3/4 years old...duralast gold. Car cranks strong until it'll pull all the amps from the battery. Sometimes it sounds like it's trying to fire too but it's weak
TMSBOSS
7,557
5,293
Illinois
The reason I asked was the 9.464 volts to the ECU. I tried to google the voltage needed to make the ECU happy but could not find the number. I have heard that anything lower than 10.0 and the ECU will not fire. No experience myself with this issue, just trying to throw out ideas and see what sticks.
12
10
North Carolina
Ah, I see. I'll double check it with my multimeter at the terminals. This was after cranking it for about 45 seconds
