- 6,602
- 8,627
Good info and something we try to remind our customers with all extreme performance DOT tires and autocross/track rubber too. Amazingly many comment on Forums and complain of horrible tire grip when chilly , blaming it completely on the tire, when the manufacturer states it should not be driven or carefully driven when temps are lower than 40 degrees. When one really thinks about it, 40 degrees is not that cold in many areas of the Country and it can affect the rubber even at that point. This is a good heads up, and we should all carry this advice over to other tire makes too, imho.
I spoke with Nitto tire engineers at the Mustang 50th anniversary in Charlotte, and this is exactly what we discussed. If I recall correctly, performance summer compounds (and slicks) have high levels of silica and some additional mumbo jumbo about long chain molecules. I just heard "40 degrees was the cutoff." Don't quote me on the chemistry, but you get the point.Good info and something we try to remind our customers with all extreme performance DOT tires and autocross/track rubber too. Amazingly many comment on Forums and complain of horrible tire grip when chilly , blaming it completely on the tire, when the manufacturer states it should not be driven or carefully driven when temps are lower than 40 degrees. When one really thinks about it, 40 degrees is not that cold in many areas of the Country and it can affect the rubber even at that point. This is a good heads up, and we should all carry this advice over to other tire makes too, imho.
Ozone generated by the motors can degrade the rubber.Keep them away from electric motors if in the basement and you can let some air out, no problem. Years ago a tire company that sponsored me racing told me to keep tires away from electric motors , though I can't remember why now -- senior moment.
