S550 PN3UMA Build Thread Profile - S550 Mustangs
Fabman
Dances with Racecars
6,559
8,213
306
367
3-5 Years
Raleigh, NC
PIX AND VIDS!
Well, we'll see about the pix and vids. About 20 minutes from home on the way to track I got a P0300 (random misfire) code. So I'm at the shop. It only misfires in the 1,700-2,700 rpm range. Never on idle and never over 3k. So fingers crossed but since it's 2:45pm, my fingers are only loosely crossed. I'm hoping it can be fixed with a quick adjustment to the tune, as the IMRC lockout on a gen3 manifold paired with a gen2 engine seems to be touchy (from what I've read online).
3
2
Durham
Old engine (turned in for core shortly after this pic). Hoping to have everything finished by next weekend. New motor is Gen2 Coyote with Gen3 intake.
I see you had to drop the subframe and lift the car off the engine. That looks like strong opportunity for a case of "while I'm in here". Hope it all goes well and you're back out on the track soon!
306
367
3-5 Years
Raleigh, NC
The only “while you’re in there” items were new OP GT4 hub/extended stud assemblies and I sent the Ohlins coil-overs in for a factory re-valve.
306
367
3-5 Years
Raleigh, NC
What is the reason for the Ohlins re-valving asking for a friend :) Hope you soon sort out the tune issues.
The owner's manual says to do it every 15 hours (Seems excessive to me). I have about 10 events on them plus some around-town driving so it seemed like a good time while the car was already in the air.
Bill Pemberton
8,507
8,544
Blair, Nebraska
After you get the Ohlins back I would, personally go on a less stringent schedule as I do believe that suggested maintenance is way too excessive for those of us not racing as a profession. I have gone years with MCS shocks not needing a thing, as well as for some of my past customers and they rarely needed an adjustment or revolving that early. I would easily triple the time and I doubt you would notice any changes. That rigid schedule is likely aimed at the pro race drivers/teams and for the average amateur trackrat the time frame for this procedure can easily be lengthened.
306
367
3-5 Years
Raleigh, NC
Yeah, I put these coil-overs on in 2020, and they have been driven to Summit Point, Road Atlanta, and VIR several times each. So I'm on a loose schedule.
Fabman
6,559
8,213
I believe the term "Your mileage may vary" applies here.
353
310
Bulgaria
I was asking more if it's a preventive thing or did you actually seen a reason to do it. Mine have like 2 seasons on them and are going good. Which is why I'm asking I know what the manual says but this are 15 hours of track time running or 60 000 km street driving.
306
367
3-5 Years
Raleigh, NC
Been meaning to get an update posted. The tune is FINALLY worked out. No more P0300 (random misfire), no more engine light, seems to run well.
So the final rundown:
- New Gen2 Coyote long-block
- New Gen3 intake manifold
- LMR IMRC lockouts (big PIA to tune, if you haven't done it before)
- HP tune
- Dyno = 404hp
Counting down the days to VIR on Oct 15, and Road Atlanta the following weekend.
353
310
Bulgaria
- HP tune
- Dyno = 404hp
That's some good numbers. Glad your car is back. Did you get your Ohlins back ? I run into an issue with my spring insulators on the front (will need to replace). Looking forward to your track days sounds like fun.
