I'm finally getting around to pulling my stock motor in the 2011 and since I have not done this before on this generation mustang, I am wondering if it is better to keep the transmission attached and have everything come out together or detach the engine and transmission and remove only the engine? It does have the MM K-member, and an MGW shifter if either has a bearing on the easiest and/or best way to remove it. BTW, I have an engine hoist and no lift if that matters. Thanks.
