This is the Build Thread for R8CEHORSE OEM+ Track Car. Leave a comment below and see you at the track!
Youtube Channel: https://www.youtube.com/@ToddMorrow/videos
Day 1:
Current Situation:
ENGINE/POWER:
GT 350 CAI.
GT 350 TB.
Ported GT-350 Intake Manifold by Paramount Speed.
Heat Shield Products IM Shield.
E85 and 91 tunes by Palm Beach Dyno.
47 lb injectors.
nGAUGE Tuner.
K&N Filter Cover.
Magnaflow & MBRP Custom True Dual Exhaust.
JLT 3.0 Oil-Air Separator.
Billet Crank Sprocket.
Billet Oil Pump Gears.
RED LINE OIL 5w-50.
Antigravity ATX-20 HD Li battery.
Custom designed Carbon Fiber 3D-printed battery tray.
TRANSMISSION/DRIVETRAIN:
Steeda Transmission Mount.
Steeda Clutch Spring.
RED LINE OIL MTL & 75w-85 Diff Fluid.
Barton V.2 Shifter.
Exedy Mach 500 Clutch.
Exedy Lightweight Flywheel.
Mcleod S/S Clutch Line.
ARP Clutch Bolts.
FP Flywheel bolts.
EXTERIOR/STYLING:
Carbon Fiber Grill Frames w/Racemesh Grilles.
Carbon Fiber Fog Light Bezels.
Carbon Fiber Mirror Covers.
Carbon Fiber Front Splitter.
Carbon Fiber Rocker Panels.
Carbon Fiber Coil Covers.
Carbon Fiber Radiator Cover.
Carbon Fiber License Plate Frame.
ZL1 Add-Ons Tow Hook.
Rear lighting by @chrisgonzales & diode dynamics
MP Concepts Rear Decklid.
MBRP Carbon Fiber Tips.
INTERIOR:
SPARCO QRT-Carbon Race Seats.
SPARCO 6 point Harnesses.
ASR Harness Reels.
Watson Racing Gen II (42 lb.) 4pt Roll Cage.
Custom Lap Belt Brackets.
Carbon Fiber GT-350R Steering Wheel.
Carbon Fiber Steering Wheel Surround.
Carbon Fiber Ford Perf. Shift Knob.
Carbon Fiber Dash & Interior Trim.
Carbon Fiber Coin Tray.
Carbon Fiber Seat Inserts.
Upgraded 8" Navi Unit w/SYNC 3.
STEEDA Race Pedals.
Clutch Pedal Extender.
Embroidered Floor Mats (F).
WHEELS/TIRES:
19x11 +52 (F/R) (Multiple sets).
Michelin Sport Cup 2 305/30/19 (F/R).
Monster Open-Ended Lug Nuts.
Ford Performance Hubs w/Extended Lugs.
25mm Spacers (F).
SUSPENSION:
STEEDA Competition Springs.
STEEDA Pro Action Shocks/struts.
STEEDA Rear Shock Mounts.
STEEDA Rear Shock Dust Covers.
STEEDA Camber Plates.
Shifteck Adjustable Sway Bars (F&R) & Endlinks.
CHASSIS:
STEEDA Jacking Rails.
STEEDA IRS Braces.
STEEDA Extreme G K-Member.
STEEDA IRS Alignment Kit.
STEEDA IRS Subframe Bushing Support System.
STEEDA Black Differential Pucks.
Lethal Extreme Through Bolt Kit.
BRAKES:
STEEDA 2 Piece Slotted Rotors.
STEEDA S/S Brake Lines.
RED LINE OIL RL-600 DOT 4 Brake Fluid.
Hawk DCT-60 Front Brake Pads.
Hawk Street Race Rear Brake Pads.
AERO:
Verus Engineering Functional Diffuser.
APR Carbon Fiber Splitter.
APR Carbon Fiber GTC-200 S550 Spec Wing.
Trackspec Hood Vents.
Day 1:
Current Situation:
ENGINE/POWER:
GT 350 CAI.
GT 350 TB.
47 lb injectors.
nGAUGE Tuner.
K&N Filter Cover.
RED LINE OIL 5w-50.
Barton V.2 Shifter.
ARP Clutch Bolts.
FP Flywheel bolts.
EXTERIOR/STYLING:
INTERIOR:
ASR Harness Reels.
STEEDA Race Pedals.
WHEELS/TIRES:
25mm Spacers (F).
SUSPENSION:
CHASSIS:
STEEDA IRS Braces.
BRAKES:
AERO:
