If you have a PP/GT350 radiator then I’m sure @5.2 liters of democracy can help you out. Just don’t use the section for the oil coolerI know that I can try and throw some cardboard at it and craft something up, but I'm kind of surprised no one has made a proper solution. Or even if there was a 3d scan of the front end that would be extremely helpful.
Yup! Sure can. I'm happy to edit the files as needed and help you get to where you need to be. Mine is designed for the 350 with the Setrab oil cooler on the FP350S:If you have a PP/GT350 radiator then I’m sure @5.2 liters of democracy can help you out. Just don’t use the section for the oil cooler
That would be amazing if you could send me the CAD files. I think the only main difference for mine would be that I’m using the Steeda crash bar, and that I don’t have an oil cooler. But I do have the AC condenser still.Yup! Sure can. I'm happy to edit the files as needed and help you get to where you need to be. Mine is designed for the 350 with the Setrab oil cooler on the FP350S:LCR-50-96 0-4063 FP350S Oil Cooler
Capaldi Racing Ford performance parts authorized distributor.shopcapaldiracing.com
Whatever your design constraints are, I can help you with a solution in CAD so you can just send it off to SendCutSend and rivet it together. Here's what I'm working with now:
View attachment 98336View attachment 98337
Sure thing! Can you PM me an e-mail address to share it with?That would be amazing if you could send me the CAD files. I think the only main difference for mine would be that I’m using the Steeda crash bar, and that I don’t have an oil cooler. But I do have the AC condenser still.
