Just had some camber plates installed and went in for alignment. The fronts were dialed in no problem but they couldn't get any negative toe for the rear. Does anyone know if it's possible to get -0.3deg toe in (the recommended track alignment spec) with the stock adjustment or will I need to install different toe links?
