Trackaster video not working
drano38
Wayne
1,130
318
Anyone else use Trackmaster for lap timing and video?
The lap timing works good on my phone and BlueTooth GPS receiver.
But the video doesn't always work. When I go to the Movie folder, I see all the mp4 files, but some have a grey icon rather than the color image of the first movie frame. Last weekend I had 9 recordings, but only the first one works. I get a "Unsupported file type" error if I click on a grey movie icon.
And my data won't sync to the MyTrackmaster server even though I've got Trackmaster and Gmail set up to sync.
Any ideas on video and sync?
Thanks
ArizonaBOSS
Because racecar.
8,733
2,735
Arizona, USA
I tried using the video one day, it was starting at the first split marker after start/finish instead of at start/finish. Also the aspect ratio on my phone wasn't great. I just use an external camera for now until they make improvements and my hardware is better.
PeteInCT
#LS-378 - So many Porsche's, so little time....
2,848
14
Connecticut
Thanks
Wayne - your phone may not have enough "HP" for all the processing it's trying to do. When I tried using TrackMaster on my single CPU Morotorola Droid it's wasn't very reliable. I now have a dual CPU phone and it has no problems...
drano38
Wayne
1,130
318
So I need TraKey for my phone too? ???
Yea, my phone may not be up to task--it's a 22 month old Samsung Fascinate, and I've learned I need to turn it off in the morning and at noon to prevent complete lockup when using Trackmaster. I'll probably upgrade at the 2 year point and see if that helps.
That may be the sync problem too (or maybe it needs to be in WiFi mode to sync those huge video files).
Thanks for the advice
713
69
Thanks
Hey Pete, how does Trackmaster work for you at Limerock? The gps doesn't seem to get a good signal there. Mine was all over the place. Do you use a stand alone gps receiver? Thanks
PeteInCT
2,848
14
Connecticut
My phone hardly works at all at LRP and I never tried trackmaster there.I do use a GTech Pro Fanatic RR GPS receiver there to log runs and it works perfectly. You can copy the data to a PC and use their software to do a good analysis of your runsand can compare one run to another.It samples GPS 10 times a second.
PeteInCT
2,848
14
Connecticut
You can go to their website and download the software and a sample data load for free so you can get an idea of capabilities.
713
69
Thanks, I googled it and found it. Looks good and affordable. Trackmaster worked great in NJMP and out at Miller. But I had no luck with it at Limerock. Looks good!!
I had the same problem trying to get my trackmaster to sync, so I reinstalled the software on the phone and it sync'd fine after that. Havent tried to use it to over lay but I guess i need to before Track attack.
drano38
Wayne
1,130
318
Bingo.
Removed, re-installed, and it synched up a couple hours later.
Luckily I already saved and moved my sessions onto my computer, because removing the program also took the session data with it.
Hopefully the video will also work now for more than a session or 2.
Thanks!
