transmission vent
Does any one know where the trans vent is located precisely? or have a shop manual w/ a pic of it? I was changing my tranny fluid the other nite and when I pulled the drain plug out the fluid came gushing out like it was under pressure. made a mess everywhere, had tranny fluid in my hair and all over myself.
I was wondering if I should drop the trans out myself or not. I unbolted the tranny mount to see if it would drop the trans enough to see it, but it only dropped about an inch an I couldn't see the vent. I do not trust the idiots at my local dealer(had issues when I wanted to order the trakkey)
7,572
5,306
If you look in the manual posted the Boss How To Forum 2012YellowBoss posted an excellent link to the ford manuals. Ignore the request for a donation.
Hopefully the links below will take you there. If not, look under:
Workshop Manuals » 3-Powertrain » GROUP 08 [Manual Transmission] » SECTION 308-03A [Manual TransaxleTransmission - MT82 Getrag 6-Speed] » DISASSEMBLY AND ASSEMBLY OF SUBASSEMBLIES Transmission case.
https://trackmustangsonline.com/boss-how-to/s197-online-work-shop-manuals-and-wiring-diagrams/
http://iihs.net/fsm/?dir=939&viewfile=Transmission Case.pdf
Good luck. :)
