What did you do to your GT350 or S550 Mustang today?
Please provide some feedback on the Drake's after you have some track days on them. I'm curious how they will hold up.
1,958
2,190
Car prepped and Ready for Watkins Glen, Monday/Tuesday with Chin.
Increased front camber from 2.1* to 2.7* using a combination of the Ford Service strut Bolts and MM camber plates. About 3mm of clearance from Hoos 315/30R19's to strut.
You don't have the struts slotted, correct? I was hoping to run that size tire all around but I don't have camber plates and I'm maxed out at -1.8 on the front with slotted struts and service bolts. :(
1,958
2,190
No I don't have the struts slotted. I did grind the thick part of each of the service bolts on one side to allow more movement. I think you'll need camber plates to run Hoos 315's with moderate-high camber. The 315 PSC2's will likely fit -- their sidewall is more tapered.
496
390
DFW, TX
The dealer is telling me they will be done with the engine swap on Thursday. Hope they torque the oil filter correctly... ;)
Picked the car up and the check engine light came on went off within first five minutes. Came on again as I passed the dealer to go home... Sitting there now while they pull the code.
It's not reassuring.
This engine has less piston slap noise though.
Sent from my SAMSUNG-SM-G900A using Tapatalk
TMSBOSS
7,608
5,370
Illinois
Ouch. Hope it's a sensor, wiring glitch.
1,958
2,190
@bpracer Be sure to check that the dealer did a re-learn on the Crank position sensor. Any Trans/Clutch/Engine swap will generate codes and a CEL without this.
496
390
DFW, TX
Not sure what codes popped, but it will be going back to fix the splitter reinstallation. Looks like the center section is not right not sitting flush. I may just do it myself though.
Can't even drive the car, the registration expired while they had the car and I'm going out of town again so can't take care of it anytime soon.
I do have plans for the car. I bought a used trunk lid painted the right color, shadow black, with no spoiler holes for $80, local pickup! And I have a hood that I bought for $600 shipped! I'll have to get it painted, or at least parts of it as it's magnetic now.
1,071
1,125
Monaca Pa
The sub belt attaches to the mount then goes between the bottom of the seat back and the bottom cushion (in the split between the two). You actually sit on the sub belts.
I know how they are routed. I figured out what I was looking at. I have your mount.
