Yes it is. I've driven his car and I can heel/toe 20x easier than the stock pedals. I'm going to have my car torn apart installing a roll bar in about a month so that would be a good time to install the pedals.
I am getting ready to install the SRP pedal covers on my GT350 too. Do you have any pointers to make the process easier? I will be doing mine with the pedals still in the car. It already seems like the dead pedal cover screws are going to be way too short. How do the factory covers come off? Thanks!8250RPM said:I removed my clutch / brake pedal box today and finally installed my SRP pedals. Also installed the gas pedal. I re-arched the clutch and brake pedal to match the factory's. Then drilled and tapped one hole for each pedal. It's not going anywhere and very solid. For the gas pedal I made a delrin button and installed it into the gas pedal where the factory cover used to be. I know, I'm nuts. But I'm a mechanic / machinist. I also put Xpel on my head lights and front marker / turn signal lights. Next I'll be removing all the front and rear suspension to install the bearings and aluminum bushings. I'm considering a 4.09 gear also while I have it out.![]()
Also installed the garage line spacer. Love it.http://uploads.tapatalk-cdn.com/20160515
/8d9a5e71e53c282e2d12a043f13010a7.jpg
There are some tips mounting them in a S197 in the thread below and most if not all of the info should apply to a S550 install. FWIW I'm going to install mine when I pull my front seats to install my roll bar. I'll install a Steeda clutch spring kit at the same time.jlwdvm said:I am getting ready to install the SRP pedal covers on my GT350 too. Do you have any pointers to make the process easier? I will be doing mine with the pedals still in the car. It already seems like the dead pedal cover screws are going to be way too short. How do the factory covers come off? Thanks!
