During my recent trip to Dearborn I met with a couple of Ford engineers and we were discussing the great Boss 302S parts availability for Mustang owners. I asked if anything was coming from the FP350S and they quickly responded with "what do you want?" I thought about it for a minute and didn't have a good answer. FP already has parts available for the S550 engine and chassis but I'm not sure what parts on the FP350S Mustang owners would want.
I was told that the front splitter would be available, it's a service part for the car, and the hood vent might also be available.
So keeping in mind that Ford Performance isn't going to make one off parts and they must have high enough volume to make it profitable what parts would you like to see?
I'll update this first post with suggestions:
1. 350S Front splitter, currently available.
2. 350S Hood vent
3. Affordable R splitter
4. 350S Backing plates for front brake ducts or complete brake cooling kit
5. 350S Sachs damper availability
6. 350S Wing end plates
7. 350S Different ABS calibration.
8. Improved diff cooler for the GT350/R
9. Breather with drain for the GT350
10. Oil pan with breather drain (for #9)
11. 350S driveshaft. Direct bolt on to the GT350?
12. 350S Camber Caster plates
13. Cylinder head mod that balances the oil pressure from side to side
14. 350S Axles
15. 350S driveshaft loop
16. 350S engine oil cooler kit
17. Upper rear shock mount
18. 350S Reinforcement (Weld on Plate at Camber Arm)
19. 350S Reinforcement (Weld on Plate at Toe Links)
20. 350S Adjustable Toe Link Assembly
21. M-1447-A Ford Performance Dash Plaque
22. Bump Steer kit
23. Confirm the front sway bar is from a base Mustang
24. Confirm that the IRS sub-frame is stock GT350
25. Confirm that the CV boots are more durable and fit all S550's
Current parts availability:
http://shopcapaldiracing.com/vehicles/fp350s-2017/?sort=newest&page=1
2. 350S Hood vent
14. 350S Axles
22. Bump Steer kit
