X-Brace
349
0
Anyone planning on trying to install one UNDER the back seat? It seems Ford went for the biggest bang in stiffness with this item. A 10% increase in torsional stiffness should be noticeable. I remember that Ford mentioned that the '11 chassis (or maybe the '10?) was already about 15% stiffer than previous years so putting the X on should result in a very stiff chassis.
I'm pretty sure the 11 chassis is stiffer than the 10. The Boss does not have the split folding rear seat so I suspect you can fit a brace back there although I'm not sure if the one from the LS will fit. Here's a rear shock tower brace but it's not an X brace. Not sure if it fits the 2010+ cars.
http://www.americanmuscle.com/steeda-2005-rear-shocktower-brace.html
ArizonaBOSS
Because racecar.
8,733
2,735
Arizona, USA
You sure about that? Sure looks like it here in this pic. If not, I hope it's at least a one-piece-full-fold...that is very critical to getting a full set of race tires and all my gear in the car for track days!!!
175
0
That Steeda brace and the Granatelli one like it are complete waste. There simply is not enough force put to the shocks to deflect the frame so how would adding a cross bar do anything? Some of these companies are looking for people to throw away money on junk. Look at the brace from Ford from the LS now that is a design that can work and it isn't bracing the rear shocks it is crossing a huge whole in the frame. Most car used to have that as a stamped sheet steel part before the pass through thing became popular.
