2012 Mustang GT_50L Profile
2012 Mustang
GT_50L  (Double0Fox's 2012 GT Trackday Build)
Specs & Mods
Ownership Status
Currently Own
Year
2012
S197 Model
GT 5.0L
Transmission
Manual
Mods - Handling
-SUSPENSION-
Maximum Motorsports R&T Springs
Maximum Motorsports Caster Camber Plates
BMR Tubular K-Member
BMR Chassis Brace
BMR A Arm Brace
BMR Strut Tower Brace
Whiteline Adjustable Front Sway Bar/W endlinks
BMR Adjustable panhard bar
BMR Panhard Bar Brace
BMR Rear Rod End Lower Control Arms
BMR Rear Upper Control Arm Mount
Prothane Urethane Upper Diff Bushing
BMR Control Arm Relocation Brackets
BMR Radiator Support W/Sway Bar Mounts
SVE Bumpsteer Kit
Koni Yellow Adjustable Shocks & Struts
-SAFTEY-
Watson 4 Point Roll Bar
Racequip 5 point camlock harnesses
Blowfish Front Tow Hook
-BRAKES-
S550 Preformance Pack 6 Piston Brembo Front Calipers
15" Front Rotors
Blowfish Front Brake Cooling Duct kit
25mm Hubcentric Wheel Spacers Front
GT500 Rear brake adapters
GT500 Rear 13.8" Brake rotors
3" ARP Wheel Studs
Goodrich Front, and Rear Stainless Brake Lines
Motul 600
Mods - Power
-POWER-
Cobra Jet Intake Manifold
Ford Super Cobra Jet Monoblade Throttle Body
JLT Carbon Fiber Cobra Jet CAI
Ford GT500 Axle Backs
BBK 1-3/4" Long Tube Headers
BBK X-Pipe
SCT X4
Peterson Custom Catch Can/Breather
Boundry Oil Pump Gears
Boundry Crank Sprocket
Setrab 934 Oil cooler
Mishimoto Radiator
Moroso 5.0L Coyote Steel Oil Pan
Lund Racing Tune
-TRANSMISSION-
MGW X-Spec Shifter
Spec Stage 2+ clutch
Spec Billet Steel Flywheel
Ford Pressure Plate Bolt & Dowel Kit
Ford Hydraulic Throw Out Bearing
Ford High Load Pilot Bearing
SVE Remote Clutch Reservoir
SVE Stainless Clutch Line
Mods - Exterior
Cervini Boss Chin Spoiler/Splitter Combo
SVE X281 Grille
Mods - Interior
OMP HTE-R Halo Seat (Driver)
OMP TRS-E (Passenger)
OMP Side Mounts D&P
Planter Driver & Passenger Brackets
Innovative Oil Temp Gauge
Innovative Oil pressure Gauge
Innovative Water temp Gauge
A pillar Pod, and Roush Vent Pod
KohR Motorsport Airbag Bypass Resistors
TMO Supporting Vendors
