Raybestos Rotors
JDee
Ancient Racer
1,809
2,012
5 miles from Mosport
Does anyone run Raybestos slotted rotors? Trying to find a more budget friendly rotor to run with gt500 brake kit
When I ran drilled or slotted rotors I found they increased pad wear and the drilled rotors were prone to cracking. I run Ford blanks, have had zero problems with them and pad wear is better.
8,507
8,541
Stay with slotted and bypass drilled as noted, but I am not much help otherwise, because time on track is not just going fast it is stopping quickly and with plenty of control. More money, but a set of Girodisc two piece rotors are my first choice and when they wear out you can just buy new rings. If overall speed and stopping power is not your goal, go with JDee and just buy Ford blanks.
