5.1L coyote swapped - Further cooling mods for road course
Grant 302
basic and well known psychic
🤣 thanks lol I had thought about going to a larger cooler and moving it behind. What kind of coolers would you recommend?
You could just try your existing Mishimoto first. But I’d say the biggest one you could fit and afford if you try another. I trust the Setrab brand, but anything that has decent test data and is over a 948 equivalent btu should work.
Fabman
Dances with Racecars
6,553
8,204
Andrew just copy mine. It works flawlessly in heavy competition and in the heat. Water and oil temps are no issue and I don’t even turn the fan on unless it’s stopped for an extended time. It just works and you've seen more of it than most have. Lol. I didn’t want to lose my hood scoop either but I got over that pretty quick and now prefer the hood louvre look.
As a rule I don’t like to locate an oil cooler in front of a radiator, you are basically pre heating the air going through it with an automatic increase in water temp
On my s550 track car I went with an Harrop oil cooler kit that seat parallel to the ground.
Pushing the car on squared 305 on a 103* track day, maximum water temp was 230 and oil 257
The cooler is a Setrab
Fabman
6,553
8,204
This is interesting....so it feeds from the lower grill and exhausts out the bottom....is that whats going on here?
Yep. You’re 100% correct. And with the removal of the factory oil-to-water cooler, I also removed a huge thermal load on on cooling system
Fabman
6,553
8,204
With the exception of feeding air to the underside of the car its a sweet setup.
I have a more traditional setup but very well ducted and I get similar numbers.
More than one way to skin the cat. lol.
EDIT: I'm at 220 water and 210 oil temp in competition. I make 477 rwhp and shift at 8k
What is your take on the no fan shroud option? What fan do you have?
Can someone explain the logic of rolling the radiator to me?
Someone can correct me if I’m wrong but as I understand it is this. The air enters the radiator at an upward angle ideally from the lower grille. Especially with large splitters this is the highest pressure zone on the front of the car as the blade is creating big downforce. The air moves through the coolers and exits the center hood vent 2” behind the radiator. This is the easiest flow path for air increasing airflow through coolers while decreasing lift and keeping the front end of the car more stable.
Basically it’s the most direct and unrestricted path through.
Fabman
6,553
8,204
Fabman
6,553
8,204
Egg Zachery.
759
1,130
TX
We’re in the Houston area. There’s an event in august but I unfortunately won’t make it. Hoping early next year.
Very cool. MSR-Houston is a pretty fun test n tune type of track. Good for cheaper track days and has a pretty great flow, IMHO.
I run COTA with Edge Addicts - next event is October 6-7 ( I think) and then there's one in December before the holidays. Feel free to hit me up if you have any questions!
Fabman
6,553
8,204
Update:
This years motor makes 507 rwhp and after 2 years of wheel to wheel competition my water/oil temps have stayed around 220/210 in all climate conditions.
captdistraction
GrumpyRacer
1,954
1,698
Phoenix, Az
Update:
That's wild - mine can get up to 260 if not more on oil, 235 on water is a pretty standard figure. If I cork up the exhaust to pass sound, oil skyrockets to 290+ in a 30 minute race and I'll flirt with 260 water temps and the associated limp modes. Half our race schedule in AZ features race times at 95* ambient which is a challenge, but if you throw in a bit of altitude or sound restriction things get real hairy real fast for a lot of the ST1 and ST2 fields from a cooling perspective.
Fabman
6,553
8,204
I can only report what I'm seeing.
Not sure how much is from efficient ducting/hood venting or my custom 3 row/3 pass radiator or how much e85 plays a part, but even at 100*+ ambient I'm seeing relatively cool temps....so at least some of this stuff is working.
Fabman
6,553
8,204
Clearly my electric water pump isn't a problem.
My god!!! That thing is still pulling to 8000 mine starts closing down at 7200 :-( What are the specs on your cams?
.576 and 252 duration @ .50 for intake
.532 and 262 duration @ .50 for exhaust.
Both cams are locked out.
The ported cobra jet ran out of steam by 8500. I’m changing shortblocks for more compression. Nothing wrong with the 11.5:1 but it had me chasing that 600 number. The new motor is a 13.5:1 on a 3.700” block. 600+ to the rear wheels now using the new MMR composite CNC intake manifold
