ABS Module swap
30
12
3-5 Years
Spanish Fort, AL
So I have attempted to swap back from the Boss race module to my stock module for street driving and anticipated rain for this weekends track event. Car drives fine but the traction control is still off and lights on dash stay illuminated. Do I have to reset a module with a scanner or something?
thanks
TymeSlayer
3,787
2,741
3-5 Years
Brighton, Colorado
Hmmm,
I've swapped mine out several tymes and never had that issue. After putting in the OEM module, the Boss reverted back to norm. I know there are a few different versions of the 302S/R module - perhaps that's the difference?
30
12
3-5 Years
Spanish Fort, AL
So I used my scanner and read codes. It showed a master cylinder low/ pressure sensor. Sure enough it was low - I guess I had ran low on fluid when bleeding brakes and hadn’t noticed. Feel pretty dumb as I have bleed brakes on this car a couple dozen times.
I filled to normal level but code won’t clear? Should i bleed master cylinder and then all brakes again?
