Patrick...that's my point. The Accufab TB was installed and run without a tune and the Ford Racing TB requires a tune...yet they are the same part....yes?
KBBOSS1086 said:I think some are misunderstanding "calibration" to mean tune. My thought is that it probably means a change / reprogram to the TPS (Throttle Positioning Sensor) is required. The Accufab is pre-claibrated while the Ford Racing is not.
302 Hi Pro said:Actually, this is not true and our cars do not use the TPS system. The FRPP 84.5 TB is calibrated and it works well as a bolt on upgrade. You get to eliminate the plastic TB spacer used with the 80.0mm OEM TB. It's funny how my stock Boss 302 (U Code engine), intake manifold mates up to the larger TB.
Also, this TB is capable of supporting high HP applications, and to maximize its full potential a tune would be required.
The drive motor and sensors are calibrated. You should install on as it will exceed your expectations. All the best, 2HP
patrickshelby said:So, basically the ONLY difference between those two TB is the engraving on the top?
And basically both the TB + AIRAID CAI can be bolted up together with no tune?!
And show an increase of HP (performance)?!
Whatever key is used?!
I still remember listening to the interview in JAY LENO'S garage with DAVE PERICAK... He was saying that none of the OEM equipment could be improved upon and that all had been 100% maximized (Intake and shifter etc ...) LOL
http://www.youtube.com/watch?v=4LXYK4rR7Sw
Are the Ford engineers really so bad? Is it a cost thing? A fuel consumption thing? A reliability thing?
I was about to grab the other one on ebay for that price. is there more to be had or was that it?302 Hi Pro said:I found a Ford Dealer, Gary Yoemans of Daytona Florida selling the FRPP TB for a buy it now price of $383.95 on eBay Motors and free shipping. It's the best price I had seen plus it comes with a Ford Dealer parts sale invoice. If there are any issues it's covered by my local Ford dealer under the parts warranty. 2HP
Justin said:I have wanted the Ford racing TB for sometime now but always didnt go after it because it required a tune which I never understood as the accufab unit doesnt require a tune. I mostly want it for the looks. (I know right) but I had upgraded TB's in the past that required a tune on my 06 GT only to have it either not idle or drive like crap. So now that I know its a plug and play operation without a doubt I will pursue one....after the wife calms down of coarse of my current debacle. Which is actually going to turn out ok it looks like.
yes.TMSBOSS said:Warranty repair?? Hope So!! 8)
Correct.Senderofan said:So your net gain with the AED tune and CAI was 20 hp? I had seen a previous thread where you wrote that the AED tune alone yielded a gain of 7 hp.
Justin said:yes.
