Boss Transmission/Clutch Issues Poll
Have you experienced any of the issues below?
  • Have you experienced shifting lock out upshifting in any gear?
    Votes: 150 57.7%
  • Have you experienced any shifting lock out downshifting in any gear?
    Votes: 57 21.9%
  • Have you experienced any grinding when shifting the car cold?
    Votes: 97 37.3%
  • Have you experienced any grinding when shifting the car hot?
    Votes: 59 22.7%
  • Have you experienced the clutch pedal partially sticking while shifting above 6,500 RPM's?
    Votes: 69 26.5%
  • Have you experienced the clutch pedal sticking to the floor while shifting above 6,500 RPM's?
    Votes: 46 17.7%
  • Have you experienced any of the above while using TracKeY?
    Votes: 76 29.2%
  • I have not had any shifting issues.
    Votes: 42 16.2%
  • I have not had any clutch issues.
    Votes: 63 24.2%
  • Have you documented any above issues with your dealer?
    Votes: 37 14.2%
  • Total voters
    260
jec246
Build date found on inside your drivers door: 2011/08/09
Do you have skip shift disabled (2011/2012 owners only)? No
Have you replaced your transmission fluid? No
Have you replaced your brake fluid? No
Have you installed an aftermarket shifter? No (Have MGW on the way)
Have you installed an aftermarket shifter bracket? No
Have you installed an aftermarket clutch line? No
Have you installed an aftermarket clutch? No
Have you tracked your car? No
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible.
None
Have you removed your clutch assist spring? No
Do you own a Boss or GT? BOSS
Build date found on inside your drivers door: 2/28/2011
Have you replaced your transmission fluid? If yes what did you install? Yes with OEM Motorcraft after first track season
Have you replaced your brake fluid? If yes what did you install? Yes Dot 4 superblue and Typ 200 Amber (many times)
Have you installed an aftermarket shifter? MGW
Have you installed an aftermarket shifter bracket? MGW
Have you installed an aftermarket clutch line? No but I do have the JHR on the shelf if we find any evidence it actually helps or if I put headers on this winter
Have you installed an aftermarket clutch? If yes what did you install? No
Have you tracked your car? Track, autocross or strip? Yes 37 track days
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible. I had an anti-rattle spring shear from the clutch disc and jam in the pressure plate last May. I had a slave cylinder fail this May. In both cases Ford completely replaced the clutch assembly including pressure plate.
Do you own a Boss or GT? Boss
Build date found on inside your drivers door: 5 Dec 2011
Do you have skip shift disabled (2011/2012 owners only)? NO
Have you replaced your transmission fluid? NO
Have you replaced your brake fluid? ATE
Have you installed an aftermarket shifter? NO
Have you installed an aftermarket shifter bracket? NO
Have you installed an aftermarket clutch line? NO
Have you installed an aftermarket clutch? NO
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible. Reported clutch pedal sticking to floor at 7000rpm up shift to 4th, Ford's response "normal operation for 7000k up shifts"
Have you removed your clutch assist spring? NO
Do you own a Boss or GT? Boss 302
Build date found on inside your drivers door: 29MAR2011
Do you have skip shift disabled (2011/2012 owners only)? Yes, No or NA-- NO
Have you replaced your transmission fluid? Yes If yes what did you install? Redline MTL
Have you replaced your brake fluid? Yes If yes what did you install? ATE Blue
Have you installed an aftermarket clutch? No If yes what did you install?
Have you tracked your car? Yes Track, autocross or strip? 3 Track days so far
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible. None
Have you removed your clutch assist spring? Yes
Build date found on inside your drivers door: 04/27/12
Do you have skip shift disabled (2011/2012 owners only) N/A
Have you replaced your transmission fluid? If yes what did you install? No
Have you replaced your brake fluid? If yes what did you install? No
Have you installed an aftermarket shifter? Not yet
Have you installed an aftermarket shifter bracket?not yet
Have you tracked your car? Track, autocross or strip? No to all of them
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible. None completed
Build date found on inside your drivers door:Will edit in date once I get home.
Have you replaced your transmission fluid? If yes what did you install? Yes, Redline MTL
Have you replaced your brake fluid? If yes what did you install? Motul 600
Have you tracked your car? Track, autocross or strip? 12 Autocrosses, 5 Drag events
TMSBOSS
7,556
5,291
Illinois
Build date found on inside your drivers door: April 2011
Have you replaced your brake fluid? If yes what did you install? About to. Dot 4
Have you installed an aftermarket clutch line? Soon
Have you tracked your car? Track, autocross or strip? Strip
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible. TSB for Fluid
Build date found on inside your drivers door: 12/2/2011
Have you replaced your brake fluid? NO
Have you tracked your car? NO
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible. let dealership know about 3rd gear lockout and clutch stayout when car was in for bad #1 ignition coil. Asked dealership to escalate lockout and clutch stayout concerns.
Lockout of 3rd gear several times
Grant 302
basic and well known psychic
I have both a GT and a Boss, responses will be GT/Boss
Build date found on inside your drivers door: Sept '11, Sept '12
Do you have skip shift disabled (2011/2012 owners only)? No/only with TracKey
Have you replaced your transmission fluid? If yes what did you install? No/No
Have you replaced your brake fluid? If yes what did you install? Yes/Yes - Both Motul RBF600
Have you installed an aftermarket shifter? No/No
Have you installed an aftermarket shifter bracket? No/No
Have you installed an aftermarket clutch line? No/No
Have you installed an aftermarket clutch? If yes what did you install?No/No
Have you tracked your car? Track, autocross or strip? Yes/Yes - Both Track, GT also autoX
Have you removed your clutch assist spring? No/No
Do you own a Boss or GT? Yes/Yes ;D
Build date found on inside your drivers door: 2011/05/19
Have you replaced your brake fluid? If yes what did you install? - ProSpeed RS683 clutch not bled
Have you tracked your car? Track, autocross or strip? Track
- I have found the clutch pedal stays down after high RPM shifts even if the car is otherwise "cold", i.e. not being run on the track.
Build date found on inside your drivers door: 05/09/12
Do you have skip shift disabled (2011/2012 owners only)? NA
Have you installed an aftermarket shifter? Yes
Have you installed an aftermarket shifter bracket? Yes
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible. N/A
Build date found on inside your drivers door: April 2012
Do you have skip shift disabled (2011/2012 owners only)? Yes, No or NA No
Have you replaced your brake fluid? If yes what did you install? Yes - ETA Super Blue Racing
Have you installed an aftermarket shifter? Yes - MGW
Have you tracked your car? Track, autocross or strip? Yes - Track
Do you own a Boss or GT? Boss LS
Sesshomurai
Build date found on inside your drivers door: Have to check
Have you replaced your brake fluid? Motul 600
Have you installed an aftermarket shifter? Yes - Hurst short throw
7
0
Build date found on inside your drivers door: 4/12
Do you have skip shift disabled (2011/2012 owners only)? N/A
I noticed a drip or two under my tansmission about a week ago, at 1400 miles, while having oil changed. Bolts were a little loose, tightened now only have drip or two every few days, andy suggestions?
I hate to have trans dropped for a seal.......
Build date found on inside your drivers door: about april 12. edit later
Have you replaced your brake fluid? If yes what did you install? not yet
Have you tracked your car? Track, autocross or strip? not yet
Do you own a Boss or GT? '13 Boss
