Exactly. So, since .09G > .03g the car will veer away from the wheel pushing more torque - The outside wheel - And in effect, will steer the car around the corner. Ever seen a skid steer Bobcat? Same idea.There's a lot of misunderstanding of how torsens function. They do not vector the torque.
A 3.0:1 TBR does not mean the outside tire is being driven 3X as fast. Think of it as the inside tires grip determines the overall grip and acceleration of the car.
If the inside tire can generate 0.3 Gs of acceleration before slipping, the outside tire will be sent 3X that amount of torque, or 0.9 GS (assuming the tire has that grip). For simiplicitys sake and the sake of understanding (at the cost of some accuracy) assume the car accelerates at 0.9 GS because the outside tire is the most heavily loaded tire and determines the majority of the cars acceleration.
Now let's say you're in the rain, and the inside tire only has 0.1 Gs of grip. The Torsen will only deliver 0.3 Gs of grip before the inside tire lights up and spins. So due to the overall decrease in grip, limited by the inside tires total tractive force, the car in this occasion will only accelerate at 0.3 Gs before lighting the inside tire up with wheel spin. The car accelerates at 1/3 the rate as the first example because the inside tires grip was reduced to 1/3.
