SN95 Chris G's GT Build Thread Profile - SN95 Mustangs
8,522
8,583
Great looking Redhead Chris , but you might want to edit your build thread because I think those rear 10x10 wheels would really get you out of the hole fast , but I bet they are hard to find, ha!! Welcome and glad to see you post your beast on TMO!!
13
Gurnee, IL
Great looking Redhead Chris , but you might want to edit your build thread because I think those rear 10x10 wheels really get you out of the hole fast , but I bet they are hard to find, ha. Welcome and glad to see you post your beast on TMO!!
Thanks, she's a 20-footer for sure. Not pretty, but building for a solid foundation and looks will come later.
5
13
Gurnee, IL
No, building for HPDE/Track use. I have a 2006 Saturn Ion Red Line that I use for Autocross. It's just not standing up well to the track use, thus the addition of this car to the stable.
5
13
Gurnee, IL
OK, got the rear axle fully rebuilt with the new Ford Performance pumpkin and gear/pinion set. Stayed with the 3-73 gear set that came with the car (31-spline axles). Dropped the fuel tank, replaced the fuel pump/strainers and fuel filter (that original fuel pump was STILL working). Welded in the battery relocation bracket in the right/rear and installed the 200-amp breaker with the positive cable to the engine compartment. Also had to weld-up a crack in the rear of the tunnel between the two upper torque box connections. I installed the BMR torque box reinforcements as well (only bolted, not welded-in), may loop back later to weld those in.
Next will be to drop the transmission for new seals, clutch, clutch cable, Steeda Quadrant, etc.
