S550 Code Orange GT500 Build Thread Profile - S550 Mustangs
208
318
75024
AND a lightning! Living the good life!
Ha, I have been on a roll in ordering/getting these hard to secure vehicles, thanks to my great local small town dealers. Had a new bronco too from last fall, that was traded in on the lightning.
Back on track, the GT500 is getting setup for SCCA TT , like my GT350 was. Even though it is bumped into the Max 1 class now, I am trying a limited prep build. Springs, bars, wheels, tires. There is a loophole that will let me run Sport Cup 2's if I run limited prep, so going to test that.
Build list:
BMR swaybars
BMR spring to be tested
CFTP springs to be tested
6gr 20x11.5 et43 rear wheels in square setup
Nankang CRS 305/20 and 325/20 to be tested
Re-used from my GT350
CMS harness bar and schroth harnesses
OP studs and spacers to run a square wheel setup
208
318
75024
The 200TW nankang CRS (used to be CR1's) are good, but not super sticky. They feel like goodyear SC3's , not as grippy as falken RT660's. The OEM Ford performance spec SC2's I bet are faster, but less durable based on feedback from others I have talked to here.
8,584
8,733
Well we will find out how the SC2s run this coming weekend as I am going to use a new set for the SCCA Time Trials at Motorsport Park Hastings. Two weeks later ( Sept. 27-28 ) the Central Region of NASA will have an HPDE/Time Trial/Road Race at the same track ( racemph.com) and then I will switch to my " Gold Standard " Hoosier R7s. It will be interesting to see how the PSC2s hold up in the weather as it is predicted to be in the mid 90s and in years past I found the Cup 2s did not get as greasy as other tires when super hot, but like every competitive tire out there the compounds have changed. I will be running on newly paved asphalt and that should help. I do know the PSC2s did get greasy on hot days on concrete surfaces , but then so did everything else.
Now, of course, I will be galloping a Pony with a bit less HP than you two Snakecharmers!!
208
318
75024
A somber update, RIP to this beast of a motor.
Looks like it dropped a valve on #5 and also took out 6 & 2 along the way. 5800mi on it, about 20hrs on track over 40 days since I bought it. Was running stock tune, and up til now had consumed one throttle body and once cat converter.
The warranty replacement has been secured, so she will be back in service in a couple of weeks in time for the next events.
