Fire suppression system..
Mad Hatter
Gotta go Faster
5,288
4,292
Santiago, Chile
I will take a look Monday when I go pass by the shop. Not sure what a flop tube is but will google it now..
my kit is as in the picture below..
6,453
8,379
it's like a fuel pickup, it basically "flops" around the tanks to scavenge the contents. But if the shop says vertical , then install it vertically. Being that short, it shouldn't be that much of an issue.
I would aske them why upside down? there should be either a flop tube or a straight tube inside the bottle, so side or upright. I can't find any recommendations on that. I personally can't recall one mounted "upside down". and our stuff is FIA.
Mad Hatter
Gotta go Faster
5,288
4,292
Santiago, Chile
Hmm... When I shake the tank around I can hear something "flopping" around inside.... Well I asked the shop why the wanted it vertical, the answer was because they always say that for all the extinguishers....o_O, Did not leave me with a warm feeling....
But I did get it wrong before, they meant right way up (lost in translation).
6,453
8,379
I know it's more work, but if it were me, I'd make half the system blue and half red, that way if there is some kind of stoppage, you'd still have 50% of the system functioning. also make darn sure you inspect those lines often, although aluminum is light, they have a habit of fracturing due to vibration.
The 2 to the fuel tank need to be under the car, you can use a bulkhead fitting for that to pierce the floor, same with the firewall.
bulkhead fitting..
