Gen2 engine swap to a S197
Mad Hatter
Gotta go Faster
5,288
4,291
Santiago, Chile
Am helping out a friend who is swapping out his dead Gen1 for a Gen 2. I assume that you need to use a gen2 pcm and harness etc?? Or can you get by with the gen1 pcm?
The engine is coming out of a crashed S550 and buying the cars gen 2 pcm is a option.
Mad Hatter
Gotta go Faster
5,288
4,291
Santiago, Chile
Looks like its easier to just add a Boss manifold that needs a home and keep the gen1 pcm etc. No blockoff needed. Looks like the harness is ok as well... fingers crossed.
captdistraction
GrumpyRacer
1,955
1,699
Phoenix, Az
The timing drive is a concern:
the Gen2 mid-lock intake phasers cannot be reliably controlled via a gen1 pcm - I know there's some tuning hacks people have tried, but nothing seems easy. I would think to get the gen2 PCM working you'd need a number of the gen2 harnesses to enable its use (along with the instrument cluster) and a lot of custom work.
Easiest bet is to open the engine up, replace the intake cams with gen1 units ($250), and install a gen1 timing system (FRPP sells a kit <$500). The exhaust cams can be reused (they're a variant of the boss 302 exhaust cam and gen1 phasers will fit them). Then all the gen1 controls and wiring can be reused.
Mad Hatter
Gotta go Faster
5,288
4,291
Santiago, Chile
Thanks!! Very much appreciated!
