GT350 Engine Mods?
What are members doing to the GT350's to bump up the power a bit? It seems the usual suspects are a bit limited at this time, Exhaust, Intake and Tune. Kooks and a few others are making headers but I haven't seen any shorty headers yet. I know shorty headers only add about half what LT headers add but living in CA I'm not going to remove the cats due to passing emissions.
Also wasn't a larger throttle body in the works? Seems I was something about a 92mm or 100mm TB from someone. @BigTaco did you see any shorty headers or intake mods at SEMA in 2016?
I'm sure AED @Shaun@AED has a killer tune for the GT350.
These JBA shorty headers don't appear to have made it to market.
http://www.lethalperformance.com/ford-shelby-gt350-gt350r/2015-2017-shelby-gt350-ford/exhaust/headers-1/shorty-1/jba-1
Has anyone installed a CF driveshaft?
http://www.lethalperformance.com/driveshaft-shop-2015-2017-shelby-gt350-1000hp-carbon-fiber-drive-shaft.html
302 Hi Pro
2,009
441
Southeast
I too went with the shorty header option on my S197 Boss 302 for the same reasons. Very happy with the shorty header install and performance gains. I run FP TracKey and didn't want to give it up with Aftermarket tunes. Also the headers changed the personallity so to speak of the Boss 302 U-Code engine.
As for the 1 piece DS? Always a top 5 list performance mod, iMO.
302 Hi Pro
In all honesty I wouldn't change the stock headers to aftermarket shorty headers. If I lived in a strict EPA state I would add borla catcback, tune, reduce rotating mass, and put the car on a diet. Don't get me wrong I love my ARH long tubes and catless x pipe, but changing the oem headers to aftermarket shortys is not worth it.
With ARH long tubes,
Catless x pipe,
Lund tune for 100 octane race fuel I pulled 536 rwhp. Using stock cai.
I've also dropped nearly 180 pounds from my car and will drop a few more from it soon.
Good luck on the throttle body!
That's a unicorn. I've been chewing FP ear on that for months. Not gonna happen.
- Forgeline wheels
- Pilot sport cup 2
- R rsd and removed rear seat
hardware and seat belts.
- ARH long tubes, catless x pipe.
- DSS carbon drive shaft
- Braille i34C battery
- I replaced all the rubber suspension bushings with bearings. The 2 stock front control arm bushings weigh over 2 pounds each, the cortex front control arm bearings weigh 1 pound each.
The stock rear control arm bearings weigh 2 pounds each also. The CorteX's weigh 1 pound each.
The stock IRS and differential rubber bushings weigh 2 pounds each, the Ford performance IRS cradle and differential aluminum bushings weigh less than a pound each.
With all the oem rubber bushing weights total 24 pounds.
The cortex and FP total are 8 pounds for everything. Saving 16 pounds.
If I decide to go with the Recaro Profi spa carbon fiber seats, that will drop another 40+ pounds.
680
215
I did not see any shorty headers for Voodoo motors. The usual players had long tubes and x pipes. I remember that Kooks had an entire system with their green cats; those would allow you to keep factory calibration and avoid CELs. This option would probably pass a CA emissions test but fail visual if the tester looked hard enough.
I just realized after reading this that I never forwarded you the Spicer Customer service reps info. They were interested in developing a one piece aluminum drive shaft for GT350 applications. Ping me on my cell on Monday and I'll forward you a picture of his business card. It's not Carbon fiber, but it would make a significant difference and "free up" some ponies.
VoodooBOSS said:
I've looked at those seats before and they are nice. Are you using the stock mufflers?
I have the stock mufflers on it now. But I also have the prototype ARH mufflers and prototype borla mufflers.
If you really want to cut weight from the seats, technocraft has these 6 pound carbon fiber seats.
https://tecnocraft.com/products/tecnocraft-t3-dry-carbon-fiber-seat
6,565
8,225
8250RPM said:
I agree. That's why I use Sunoco 260GT 100 octane.
How much do you pay for 100 octane?
Its around 8 bucks a gallon here, and significantly more at the track.
I usually pay 2.50/gal or so for e85 and with the savings in fuel cost I can buy a warehouse full of fuel jugs to bring to the track.
I have a 55 gal drum, a 25 gal drum and 8 fuel jugs. When the price gets closer to 2.00/gal I go fill up.
Then I just pump from my own personal gas station here in my shop as needed.
The real bonus is that it runs way cooler than any gasoline-racing
or not-so you can tune much more aggressively.
On my blower car it's a difference of more than 100 hp so it's a no brainer for me.
N/A cars will benefit from the cooling nature of e85 too, although not nearly as much, however the costs savings do still add up.
The reasons why I don't want to use e85 in my car are...
1) I live in a small rural town, we have E85 available, but I have a strong doubt it gets sold much and I do not want old or stale e85. I know how to and know I can test it before filling up, but I'd rather skip the hassle.
2) as little as I get to drive my car, I don't want the E85 sitting in my tank and going bad.
3) I get a 55 gallon drum of Sunoco 260GT for $340 without a drum deposit. With a drum deposit it's $320.
Plus I use it in my 2016 Norton Commando 961 air cooled motorcycle.
6,565
8,225
e85 is awesome stuff, but it's not for everyone. ;)
6,565
8,225
8250RPM said:
I'm not disagreeing with you. I have a F150 I use it in when I take it to the track.
I know you're not, I'm just pointing out the benefits for those whom it might make sense for.
In my case I had to run 106 octane @ 16.75 a gallon and after one track day I said "Oh, HELL no"....LOL.
