I did because I drive my car to and from the track. With the valve stems and sensors I've posted it's inexpensive to do. I still need to confirm which sensors work on the GT350.
I didn't either, but on my earlier S197 I had to reprogram the stock wheels when I swapped off the track wheels/tires. I will plan to run them on the GT350 though to save time taking pressures after every session.mattlqx said:I just didn't run TPMS on my track tires
cloud9 said:I didn't either, but on my earlier S197 I had to reprogram the stock wheels when I swapped off the track wheels/tires. I will plan to run them on the GT350 though to save time taking pressures after every session.
AMPowerJ said:In for more info on the proper TPMS and valve stems. Honestly I never knew valve stems were rated for a certain speed limit. Good to know!
VoodooBOSS said:The correct part # is:
GT350 TPMS Sensors Ford FR3Z1A189A
Welcome to TMO. Yes Rock Auto is a great source for the stems. Do you have any photos of those tires mounted on the stock wheels? Any rubbing up front?yWill_Drive_For_Food said:Rock Auto has these for about $20. Known as both TPMS39 and FR3Z1A189A. These are the steel stems with TPMS that come from the factory. I'm running 315/30/19 Sport Cup 2 on all 4 corners on the factory (non-R) wheels. Learning process worked the first time and the dash readout is accurate enough for track use.
Thats a great tip!blacksheep-1 said:FWIW, check the valve stem nut every day, I've had them vibrate loose, even when properly torqued..(35 inch pounds I think..not sure) in any case, I've marked ours with a paint pen so I can visually check them
Thanks for the info VoodooBOSS!
I just received the OEM TPMS sensors with the metal valve stems and I just placed an order for the Dill valve stems to see if they mate to the OEM TPMS sensors. If they do then I will have two complete sets. I'll report back my findings once the stems arrive.
$85 for set of four? I have not seen them that cheap, more like $45 a piece.Mark, order the stock sensors and they come with the OEM metal valve stems. About $85 delivered for a set of four. They work fine on the Apex wheels.
Says $50.59 on their websiteAutomation White Bear Ford has them for that price. Bought a new set for my Apex wheels.
