S550 GT350R Race Car Build Build Thread Profile - S550 Mustangs
1,938
2,041
@Tonymustang302 I believe they are no longer available. Part number is M-19515-M50
@Jet One Duane, I don't anticipate being able to measure any difference. I'm hoping it will lower temps on Cylinders #4 & #8, but any decrease there will likely increase temps on the other cylinders. Next engine teardown and Leak-down testing will tell.
Meanwhile, Got the Headers installed and got the Powertrain back in the car today:
771
1,168
TX
Hey Nick - what's your break in procedure since the car isn't street legal. Do you do a full break in on the dyno?
1,938
2,041
How well are you able to get the corner weights equal. No cross but at each front and rear axle?
@steveespo I didn't pay much attention, as I just wanted to get it right pre dyno and I'll fine tune with ballast, now I have the Dyno results. Last season front left was 87lb higher than right and rear left was 102lb higher than right at 50% Cross weight.
Car dyno'd up 3 rwhp peak and average rwhp after rebuild so I have to add an additional 24lb of ballast. The (much) better news is torque was WAY up (anywhere from 8-26 ft-lbs from 3,000-6,400rpm)
steveespo
Lord knows I'm a Voodoo Child
4,025
1,980
Cookeville TN
Thanks Nick, Those numbers are similar to what Ernie and I saw. He thought we could get left/right closer to equal but with my ballast on the left side no way.
Steve
