Huge brake upgrade for S197 chassis
cholmes1
400lb Gorilla
352
222
Denver, CO
Other than the Cortex cambered solid rear axle (~$6K + brake options) none that I am aware of.
Thank you for the feedback, unfortunately, this is the Cortex response
"Unfortunately the GT350 rear setup will not work. There are some specific packaging limitation the biggest one is the need for a real deep rotor hats. Usually they need to be around 50-60mm deep.
Buying beyond that the GT350 rear brakes would not be my top choice for rear brakes on a S197. They are too large and our testing on the Gt4 program has proven that any rotor larger than 328x28 has no benefits and is only adding weight. In fact, even the OEM s197 brakes when used in the S197 with the superior stiffness of he CV Cambered axle work very well on serious race cars. We do have a number of brake packages we offer that are listed on the CV axle webpage.
Best regards,
Filip"
Since I am only really interested in staying with OEM options, I will likely remain with the GT500 rears and look at different rotor options. Sadly, with such a short production run the options are pretty small (3-5 options from my research)
Duane Black
Curbs go brrrppp
587
429
Durham, NC
I didn't take pictures, but I got the caliper last night. A beast compared the two piston slider I have for sure!
I've read in this thread that the banjo bolt is known to break off in the caliper, the one that compes with the Stoptech stainless lines. I noticed the stoptech banjo bolt is a shorter thread bolt than the standard length. I checked how far a more standard banjo bolt will go in with and without the hose just to see how far frmo bottoming out I am, and it appears that the longer bolt that is more traditional bottoms out about 1/4 inch from hitting something solid in the caliper, with the copper washers and hose installed to put everything where it should be.
As long as it can push fluid into the caliper, how far it is into the caliper shouldn't matter, correct? It's just a little bit annoying long to thread in and out of the caliper?
captdistraction
GrumpyRacer
1,959
1,706
Phoenix, Az
Best regards,
Filip"
That's good to know, I had been considering that along with their floater axle (I have a spare set of GT350 rear calipers). I thought initially they'd offer decent pad life.
captdistraction
GrumpyRacer
1,959
1,706
Phoenix, Az
As long as there's some clearance at the bottom, it should be fine.
cholmes1
400lb Gorilla
352
222
Denver, CO
Spoke with James at FTB and he said if you have the Cortex floater axle they can get the GT350 rears to fit and operate. Too rich for my blood and needs, but thought I would pass it along
I may have a solution for guys who only need front lines to do this S550 upgrade and buy the StopTech 950.61003. The solution being a different Banjo bolt than that's provided (which can easily break). Use a Dorman 13940 available at most autoparts stores. I'm not usually a fan of Dorman, but this piece looked the part and I tested it to 30ft.lbs in the caliper to make sure its up to the challenge and no problems.
You can't re-use the OEM S550 banjo bolt because it's too long when used with the slimmer StopTech hose fitting end. And the provided one breaks. So this Dorman part is a little longer, but when tested alone in the caliper it threads until there is 7.4mm gap between the caliper and bolt. Which means, with the 8.4mm hose end + washers for like 9.5mm there's plenty of space being taken up before it would bottom out. And, as I said I torque tested it in the caliper no bottoming out.
Washers fit the same. Banjo exit hole lines up with the middle ST fitting end.
As an added bonus, the Dorman part fits much more snugly in the thread engagement due to the ST banjo bolt thread diameter being undersized by .2mm or so.
Cheap $4-6 solution.
I'll edit this if any issue arise from use.
As an update, installed with the Dorman 13940 banjo bolts with the StopTech lines. I torqued them 9-10ft.lsb over at 38ft.lbs for science - just so i don't recommend something that's going to break 10% over. Held up great, holding pressure well. The fittings and hardware in the StopTech kit really leave a lot to be desired, they definitely warrant their low price point.
On an unrelated note, the caliper hardware kit and 1mm titanium shims from Optimum Performance are WAY nice. Made a bigger difference than I expected after taking out the old rusty hardware that only had 11k miles on them.
1,289
1,113
Philly Metro Area
5mm (actually 4.7mm)
6mm
6mm
Thanks Coz! Vorshlag is saying I must use longer wheel studs with a 5mm spacer. Would you agree for my Boss 302?
1,289
1,113
Philly Metro Area
Correct. You want to make sure you have enough thread engagement with the lug nuts.
Yes! but I think more to the point,,,, do not use the stock studs at the track
Mad Hatter is correct. Especially if you are running wider & stickier tires.
On your S197, as long as you can get 10 full turns of engagement you are in the clear. At a minimum we want to see a full diameter of engagement on studs. The S197 studs are 1/2"-20 thread, so to achieve a 1/2" of engagement requires 10 full turns.
For the S550 with it's M14-1.5 threaded studs, you will want 9.5 full turns.
