- 54
- 0
Somehow, I lost my silver key to the boss and the track key tune is causing detonation. DOes anyone know how much a replacement key is? Good god....I don't want to ahve to buy another key. I have one place left to look but just thought I's ask.
Have you seen this from the TracKey instructions?Superlead76 said:Somehow, I lost my silver key to the boss and the track key tune is causing detonation. DOes anyone know how much a replacement key is? Good god....I don't want to ahve to buy another key. I have one place left to look but just thought I's ask.
Superlead76 said:Thanks everyone. I'm going to the dealer and see if I can get another BOSS key. I want the one with the Silver boss logo on it instead of a generic Ford key. More to come.
Dark Horse said:Has anybody tried cloning the red Track Key using the ON-BOARD PROGRAM procedure? It would be interesting to know if we can make copies of both keys by simply alternating which order the original keys are inserted. I've attached a link to the ON-BOARD PROGRAM write-up.
BOSS X said:Dark Horse said:Has anybody tried cloning the red Track Key using the ON-BOARD PROGRAM procedure? It would be interesting to know if we can make copies of both keys by simply alternating which order the original keys are inserted. I've attached a link to the ON-BOARD PROGRAM write-up.
From the TracKey Customer Instructions:
Can more than one TracKey be programmed for a vehicle?
No. Only one TracKey can exist for a given vehicle at a time.
2012YellowBoss said:Dark Horse said:Has anybody tried cloning the red Track Key using the ON-BOARD PROGRAM procedure? It would be interesting to know if we can make copies of both keys by simply alternating which order the original keys are inserted. I've attached a link to the ON-BOARD PROGRAM write-up.
As far as I know it can not be done, simple because the active red key itself needs to be programmed. The link you posted is for PATS programming and if you follow this with a red or black key you will have a working normal key to start your Boss but not with the Trackey programming.
2012YellowBoss said:Any late model Ford PATS key will work, with or without the keyless entry. The Boss comes with a 80 bit "SA" key but a 40 bit "S" key will work fine. I know since I programmed two Bosses with "S" keys but get the new "SA" if you can just for the hell of it. You can get them off ebay from this guy http://myworld.ebay.com/ebaymotors/chapstick4
You have problems now, first off you need the dealer to program a second key since you only have one working PATS key left. You can not PATS program the second key with just one working key yourself. You will also be the poster child to see how this will screw with your Trackey programming since the single key you have (red) will need to be reprogrammed along with the new one. I asked Ford Racing how would this effect the red key and they did not know but said if anyone needs to do this to call them first. My guess is you will need all or part of the trackey program again.
Everyone - always have three keys !!!
also read
http://forums.themustangsource.com/f813/how-many-keys-do-you-get-494183/
808Boss said:Thanks, I ordered a key. Should I get the key cut by a locksmith, dealer, or you think any place would be fine?
2012YellowBoss said:808Boss said:Thanks, I ordered a key. Should I get the key cut by a locksmith, dealer, or you think any place would be fine?
Any place will be fine, I had my Mustang key cut by the dealer but Home Depot cut the last key for my truck.
808Boss said:I have track key installed as well. When I program the new key, that won't do anything to the track key program will it? Thanks again...
