Nitto Tire question. About to get NT555R II
5,261
4,258
Hi! I am about to get a square set of NT555R II tires in 305/35-18 on a set of 18x10 Drifts. I noticed that the Nitto NT05 is about US$100 less per tire..... Are they in any way comparable (in a 295/35-18)?? If I have 305's up front, what spacer size should I get?? I wanted to get the spacers at the same time, am assuming that longer bolts are need with spacers.
Wanted to stay in a "semislick" class without Hoosiers for now. The NT555R II's let me run with the more "normal" cars.
ArizonaBOSS
Because racecar.
8,730
2,734
Arizona, USA
The 05 is more of a high performance street tire than a competition tire. Check the treadwear ratings but IIRC the 05 is a 200 and the 555RII is 100(?).
The 555R II is a R comp tire the other is not. They are not comparable. See the what's needed to go square thread for help on spacers.
5,261
4,258
PeteInCT said:
305's up front? Watch the brake cooing ducts !
-Pete
Too true, even with 275/35-19 tires I had to install a short section of rigid pvc to avoid the Rub. I am hoping that with the reduced diameter, a +- 5mm spacer and the 42mm offset, that I would get by.
Need the extra stick to get those Camaro Zl1's!
5,261
4,258
Re: Nitto Tire question. About to get NT555R II
Thats with the original diameter duct?? My short section of pvc pipe is about half the diameter of the original duct right were the tire would rub, gives more then a inch of extra space. It was a shame to see, and hear, the rubbing!! Might have lost a bit of cooling but overheating has not been a problem for a while now.
5,261
4,258
No rubbing at all with the 305's. But after two track days they look like they only have one or two events left[emoji30] . Just as well they are discontiued!
My buddies hoosiers are lasting much better.
PeteInCT
2,848
14
Connecticut
Hoosier R6's don't last as long as the 555RII's, they are much softer. If your buddy's are lasting longer then he's not pushing the car like you are. I ran 555's for > 1 season and am now on R6's. As far as the discontinue, the NT-01's are taking their place - but the available sizes are different....
-Pete
5,261
4,258
Thats good to know!! At least the NT01's are in 305/35-18. Will try to keep them alive for a while longer. Do you run them till they cycle out? or till the tread was worn away?? Was even thinking of going to 295/35-18 Rivals to help out the budget a bit.
In any case the 555's did finally get me ahead of one of my nemesis, a ZL1 with Toyos, Tune and a complete Borla setup.
https://www.facebook.com/timeattack.chile/photos/ms.c.eJwVyMERACAMArCNPIGWyv6Lqc8kpYnBtujRSumA0fNO~_B2g3SbeX~_fuCZ8~-.bps.t.1195291176/943796125632673/?type=1
PeteInCT
2,848
14
Connecticut
I run all my tires until I can see the inside ::)
